08/03/09, 05:18 PM
#1
Sacramento
My 74 has an after market ignition switch in it. I bought an ignition switch door lock combo from BC. I have a wiring diagram that shows the wires that go to the switch but not which terminal they go to.
Any one have a better diagram or can tell me where they go? None of the terminals on the switch are marked.
Thanks.
08/03/09, 05:58 PM
#2
It's not dented, it's just been environmentally streamlined!
Aurora, CO
Try these. You might have to use an ohmmeter to figure out which terminals are which but you can see the factory wires colors here.
74 Sport U151, 5.0 must-plorer EFI, C4, PS, front discs, twin sticks, 3.5" susp/1" body, 33's, 4.11's, ARBs, Hickey Sidewinder
08/03/09, 10:51 PM
#3
Sacramento
Thanks Viperwolf, I think that is going to do it. Assuming the two loops go around the post and the ground goes to the outside terminal.
08/03/09, 11:17 PM
#4
Aurora, CO
Yes that is correct.
08/03/09, 11:57 PM
#5
Sacramento
Thanks much.
08/05/09, 01:20 PM
#6
Sacramento
New switch in, everything works. I am so happy. Thanks again Viperwolf.
I was a little disappointed in the quality of the bezel, keys and lock cylinder.
On to the door locks.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
