- Mar 8, 2007
- 81,747
Well this turned out nice! Kind of a pain to install. I still need to clean up the wires and rcas.
looks nice...
?What's the hole in the O in the plate for?
Bolted it to the bumper
That should work if it's still the one I'm thinking of. One of my design goals years ago was to not have to cut/enlarge the firewall hole to make it work and Hydratech's design copied that bracket so you should be good. At the time, I was running the Mustang 5.0 upper that you have, along with no body lift, so I think it should fit fine. The clearance to the intake is always one of the top design considerations.Duff has a version that is no cut, which might work great.
Yep!That should work if it's still the one I'm thinking of. One of my design goals years ago was to not have to cut/enlarge the firewall hole to make it work and Hydratech's design copied that bracket so you should be good. At the time, I was running the Mustang 5.0 upper that you have, along with no body lift, so I think it should fit fine. The clearance to the intake is always one of the top design considerations.
Todd Z.
I went with the old bracket and sourced the pivot arm on eBay. With 351W it fits better angled for me. Sourced lines from WH. Then on budget, used astro van HB. Works great. You will love the braking power!Well decided on hydro boost. Gosh that brake booster was huge.
Any suggestions? I have an explorer power steering pump.
Any issues mounting your air compressor on the firewall? I'm hoping to get my brakes done up this weekend then mount my ARB pump somewhere in there as well. Thanks.I went with the old bracket and sourced the pivot arm on eBay. With 351W it fits better angled for me. Sourced lines from WH. Then on budget, used astro van HB. Works great. You will love the braking power!
No real issues. I wanted it up high and out of the way. It is a bit loud but I do not run it too often. For the rear locker and airing up the tires. Access to the back was through the top vent hole.Any issues mounting your air compressor on the firewall? I'm hoping to get my brakes done up this weekend then mount my ARB pump somewhere in there as well. Thanks.
For some reason I always thought the washer bags looked cool. I never liked the big plastic tank I had prior.
Now time to find an overflow tank I like.
Out with the tuffy glove box. Back to stock.
Next winters project will be stock looking direct port Efi. That would get wide of like half of the wires in behind my dash. It’s such a mess.
