Landscapepoke
My old electronic ignition went out and was told to buy a new Pentronix Ignitor 2.
Here is the old one.
This was the old points system.
I bought a Pertronix Ignitor 2 at the suggestion of a friend of mine.
Found out I need a plate for the Pertonix to sit on.
My question is this: Does the new plate screw onto the inside of the distributor. No Screws came with the plate. Does the lever that attached to the old points, attach to the new plate some how? I set the plate in the hole, but the lever got in the way. So I took out the lever, put the plate in, then the lever fit inside the new plate. Does it just sit inside the plate or does it attach to anything.
You all helped me with my over heating problem. I havent been able to drive my bronco for a couple of months and its driving me nuts.
Many thanks.
Many thanks.
