- Sep 17, 2018
- 249
Stock 302 V8
Last week it took me ~15 minutes to start it up after sitting for ~5 days. Normally it fires up in an instant with a pump of the gas pedal after sitting for same amount of time. Strong crank, getting gas. Started to fire once, then twice, eventually started and ran smooth/normally. Sat overnight and started fine.
Started hardish today (~20 seconds) after sitting for 24 hours.
Under the distributor cap everything was coated with a thin layer of copper dust, so I wiped off the rotor and contacts. I'll see if that helps tomorrow
The plugs and wires were replaced 3 years and 25,000 miles ago. When running it doesn't feel down on power, and the fuel economy is slightly lower than during the summer (as it usually is at this time of year).
Any ideas?
Any ideas?
