Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 05/10/14, 07:59 PM   #1
Tonkabronco
Newbie
Long travel shock hoops
Hello Classic Broncos, my name is Mike and I am starting a new off road products company. We plan on offering a variety of innovative off road and outdoor related products, but our real passion has always been EB’s.
We’d like to start by offering our new EB long travel shock hoops. These are designed for those of you who want to run a single smooth body style shock, with or without a remote reservoir (like Fox, Sway-a-way, Bilstein, etc...) The mounting tabs have 1 ¼" spacing. This version requires at least a 1” body lift.
They are constructed of .120 wall D.O.M steel tube. All the flat parts are laser cut ¼” HRP&O steel plate. The shock mounting tabs are 3/16” steel and are gusseted on top. The tubing and flat pieces are precision notched and fit, then everything is assembled and welded in several custom jigs.
The Front Hoops come with all-new grade 8 hardware. The hoops bolt to the top portion of the coil spring bucket and use a backing plate to reinforce the connection. The frame end of the hoop bolts to the frame with a 9/16” bolt. Also included is a frame reinforcement sleeve that will need to be welded. The ends of the sleeve are beveled to make welding it in place simple. As always, 76 & 77 models may require some modification to the driver's side inner fender well.
The rears come with all-new grade 8 hardware. They mount the shock in the forward leaning position, and will require some very minor trimming of the sheet metal edge on the bottom of the rear inner fender well. You do not need to cut the actual inner fender well, just trim the bottom edge. They bolt to the frame with three 7/16” bolts and use a backing plate. They have a .120 wall DOM tube that bolts in place and ties them together for strength. This also stiffens the rear portion of the frame. The tube snouts are made from .188 wall DOM tube and are finished off with a pressed-in billet aluminum end cap.
They come in a high-quality powder coat finish, in your choice of either the popular hammer tone grey, or a 40% semi-gloss black.
The price will be $230 per set (FRONT OR REAR) but for this first run, we would like to offer them to Classic Broncos members at $10 off per set.
If you would like to buy a set, need help installing them, want to give us input on our products, or just talk about Broncos, give me a call, PM or Email. I hope you like the first of many products to come.
Thanks,
Mike
(661)618-4508
tonka88@sbcglobal.net
Click image for larger version
ID:	336325   Click image for larger version
ID:	336326   Click image for larger version
Name:	blue bronco 08.jpg
ID:	336327   Click image for larger version
Name:	blue bronco 02.jpg
Name:	blue bronco 09.jpg
ID:	336329   Click image for larger version
Name:	Front details.jpg
ID:	336330   Click image for larger version
ID:	336331   Click image for larger version
Name:	blue bronco 10.JPG
ID:	336333   Click image for larger version
Name:	blue bronco 11.JPG
ID:	336334   Click image for larger version
Name:	Frame reinforcment kit.jpg
Tonkabronco is offline   Reply With Quote
Old 05/10/14, 08:09 PM   #2
TwoDalesDad
Looks like you Guys build some nice parts.....they should sell themselves
TwoDalesDad is offline   Reply With Quote
Old 05/10/14, 10:13 PM   #3
fkngiant
fkngiant's Avatar
One of the many passions the wife says I cant afford. Ha
Phoenix,AZ
They look great. What length shocks will this kit support?
"Prolonging a boring life is worse than not starting it in the first place. This is why you must not drive a Toyota Corolla."
- Jeremy Clarkson 1997
fkngiant is offline   Reply With Quote
Old 05/10/14, 10:22 PM   #4
Tonkabronco
Newbie
Thanks, My blue truck in the pictures has 4 1/2" of lift and I'm running 12's in the front and 10's in the rear
Old 05/11/14, 01:38 PM   #5
markyyg
markyyg's Avatar
there are three types of people: leaders, followers, and disrupters
decatur, tx
Hoops
Could u give me shipping on two fronts to 76234, thank you
markyyg is offline   Reply With Quote
Old 05/11/14, 04:07 PM   #6
Tonkabronco
Newbie
26.38 UPS ground for 1 set. Were you looking for 2 sets?
Old 05/12/14, 10:46 AM   #7
ren71
SoCal
Is $230 the discount price or is it $10 off of it for a total of $220 for each set?
ren71 is offline   Reply With Quote
Old 05/12/14, 11:14 AM   #8
Tonkabronco
Newbie
$220 is the discounted price
Old 05/12/14, 08:01 PM   #9
Joker11
Joker11's Avatar
Jeeps are like A-holes. Everybody has one!!
Yuma, Arizona
Not to hijack here.
Just an FYI to newbies: DOM is tubing that is Drawn Over a Mandrel. It maintains a constant size. It it is made from sheets of steel and welded together, then drawn over a mandrel that will cold form the weld area.
HRP&O is metal that was hot rolled (made while red hot) then pickeled in an acid bath to remove surface slag and then oiled to prevent rust. The oil would later be removed to weld and to coat.
Joker11 is offline   Reply With Quote
Old 01/29/16, 10:53 PM   #10
golfobx
Suffolk, Va
Anyone hear from this guy anymore? I really like the rear shock mount but can't seem to get ahold of him!
Anyone running one of these rear mounts?
69 bronco, d44 front , 9" rear, 4.11, detriot tru trac, 4 wheel wilwood disc brakes, hydratech hydroboost, 347 stroker, PS, c4 custom with all billet everything, d20, 3.5" lift, 33x12.50x18, Holley efi, duff long arms, bailie bilt cage
golfobx is offline   Reply With Quote
Old 12/14/18, 10:25 PM   #11
snick
Pasadena
Does anyone know what happened to this guy? I really like his set-up and would love get my hands on one of them. I've tried to contract him multiple times over the last 2 years but have never heard back. Or if anyone has one of his set-ups that they're not using, please contact me.
68 U15 NV3550 Explorer 5.0 swap with mustang EFI 3.5 suspension lift 33" tires
snick is offline   Reply With Quote
Old 12/15/18, 08:47 AM   #12
bronconut73
bronconut73's Avatar
How did you do that?
Orlando
Try Migs here on CB...
I think that's his handle.
Good stuff Bud,
'73, 3.5" sl, XL RS9's, F-250 mounts, Duff long arms, 1" bl, 35" MTZ's, C-4, twin sticked, P.S., built 351W, Exp Serp, F&R Detroits, 4.11's, chromo axles, 11 leaf packs, SuperJoints, Chevy front disc, BC rear disc, BC Vintage a/c, Scat Procar 2K seats, Alpine/Pioneer, Bear, Cobra 148 GTL/Texas Star.
bronconut73 is offline   Reply With Quote
Old 12/15/18, 10:13 AM   #13
langester
MASTER OF MADNESS
langester's Avatar
There are Very Few problems well placed ordinance won't solve!
Cortez, CO
I recall seeing these for sale on Ebay at one time. Not sure if it is the same person or not but they sure look the same.
1972 Bronco "Spawn Build" still in progress.
langester is offline   Reply With Quote
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
Copyright © 1996-2019 All rights reserved. Privacy Statement
Page generated in 0.42907 seconds with 62 queries
