GSP9
Thought I finally got all the leaks fixed in the Bronco but walked into the garage this morning and noticed fluid under the front axle (both axle seals (Dana 30)) and a spot up front which was dripping off the pitman arm. Traced the leak from the pitman arm up to the top of the power steering box. I had the Bronco out two days ago and maybe put 30 miles on it then parked it in the garage. No leaks yesterday but almost two full days later there's oil on the floor.
I'm not too concerned about the axle seals. It goes in for inspection in a few weeks and the guy I take it to can do those with his eyes closed so I'm just going to let him do it. I attached a picture of where the box is leaking and adjacent to it looks like an old leak. Is this a pretty easy fix in that it's just that seal between the body and the top plate of the box?
