acharlierock
- Joined
- Apr 19, 2011
- Messages
- 18
One of the first Broncos ever created in 1966. Also, one of only 20 "Numbered Editions" from BC Broncos. Only a select few will ever be considered a B.C. Broncos "Numbered" restoration. These trucks were 100% restored by B.C. Broncos. Each received a frame off, nuts and bolts tear down, followed by a ground up build using new parts and of course many BCB Original goodies. BC Broncos typically only accept 2 "Numbered Edition" restorations per year. If you want to join the ultimate Bronco owners group, this is your chance. Link for more information below. # 7 of 20, link here. (Rockwood Buildup)
https://bcbroncos.com/bronco-build-up/
Only 4,559 Miles on this since the Frame off Restoration in 2012. Crate engine (V8, 302, 5.0L), Rebuilt Transmission, Fuel Injection, Custom Stereo Sound Bar, Disk Brakes, Air Conditioning, Power Steering, All Weather Seats, Custom Soft Top, BC Broncos 3 Core radiator, Heavy Duty Front and Rear Driveshafts, BF Goodrich All Terrain Tires (33 x 12.50), Painless Wiring Harness, 2-Into-1 exhaust with Magnaflow Muffler (Sounds Great), BC Ceramic Headers, 23 Gallon Fuel Tank, BC Tie Rod Kit, 2.5" Lift, F-150 Vents, New Steel Hood, and pretty much everything besides new axles were installed in 2012 by BC Broncos in Texas. Sony Bluetooth stereo with custom surround sound speakers were installed in 2015. The chassis is in excellent shape, and the body has been rhino lined inside and out, so no rust. Text me with any questions you have. Only current issues are the horn and left hood shock do not work. I never use the horn and the left hood shock is still functioning to hold the hood up so haven't cared to get them fixed.
VIN: U13FL738667
Pictures can be found below.
https://losangeles.craigslist.org/lac/cto/d/1966-ford-bronco/6676632083.html
VIN: U13FL738667
