gmorrison124
I stumbled upon this Bronco which came from a south TX deer lease.
We made a deal and I towed it home. The body is in good shape with only a couple of rust troughs in the floor boards. It had the wrong radiator which had a big hole in it so I pulled it, put a wrench on the front of the engine and thats when the "project" began....
So;
'69 UN-CUT body... There are some dents as this was a hunting truck
*Engine rebuilt, 302, .030 over bored, .010/.010 crank, heads rebuilt with all new valves and hardened seats installed under the exhaust valves.
* Weiand Dual plain manifold
* Holley 90470 Truck carb 470 CFM, elect choke and vac secondaries.
* replaced clutch and pressure plate
* went through the transmission and checked all the bearings and syncros, replaced the seals
*Rebuilt the Dana 20 transfer case and replaced 1 bearing, seals, front output bearing retainer
* Both drive shafts rebuilt by local shop and balanced
*NEW, Correct radiator and new hoses
*New fuel tank Kit and replaced fuel line.
* electric fuel pump, low pressure
*Brake system rebuilt, wheel cylinders to master cylinder. New lines, hoses, front drums and shoes.
*Pulled steering column and repaired shifter to function. replaced plastic spacers after cleaning shift tube then lubricated before assembly.
*Replaced front axle C-bushings and radius arm bushings.
*Original bucket seats were rusted to pieces. I still have them and a good back seat frame assy. I installed some bucket seats my son had... their ok.
*4 new BFG 31/10.50 - 15 tires on Ford F-150 wagon wheels. Wheels were blasted and painted before new tires installed.
I welded a patch in the floor under the passenger outside seat bracket. The under body support was still in usable shape
* This truck already had the Roadster door inserts and I DO NOT have doors for this.
* There is a square hole cut in the bed by the PO and I have no idea why. I will weld this back in place.
* The PO supplied a '74 under dash wiring harness as the original has been cut up. I'm still working on getting lights a gauges working to make it street legal.
I have left the body as I received it so you can choose what you want done and the final color.
I will answer questions and supply more pictures if you PM, text or email me.
Asking $11500.00 OBO Price drop, $10500 OBO
I'll get pictures up as soon as I figure out how.
[URL=http://s1272.photobucket.com/user/Hazmat3124/media/20180717_173248_zpsykstfbpp.jpg.html]
[IMG]http://i1272.photobucket.com/albums/y384/Hazmat3124/20180717_173248_zpsykstfbpp.jpg[/URL][/IMG]
So;
