- May 24, 2004
- 3,411
Bondo
Here are a couple shots of the bondo Keith is talking about. This is the rear corners - some places were thicker than this (like between the rear corner and rear fender).
I also welded up the seam in the rear where the tail light corners connect to the Body.One had a 1/4 in gap and the other had 1/2 in gap and both quarters were filled with Bondo.I didnt know Bondo burned like it did as it made it hard to weld with the fire F&%$ing everything up.Did I mention I hate BONDO and believe people who fill a vehicle should DIE.There is a reason to use filler but it should be a 1/16th or less reason.
