377
1977 Bronco U-15 Wagon
Complete frame off restomod. Has approximately 250 miles on build. I'll start from the ground up on what was done to the truck.
Frame
Frame and both axle housings were powder coated
Both axles have chromo axles (Rear are 31 spline axles)
Ford 9' has Tru Trac Locker
Ford 9' has Ruff Stuff pinion guard
Warn locking hubs on front end
All new brake components
WH braided extended stainless steel braided brake hoses (master cylinder to prop. valve, rear frame to rear axle and front brake hoses)
Hydratech Hydroboost Brakes
JBG shocks on all four corners
Hellwig Sway Bars on front and rear (front is off-road version that can be disconnected)
James Duff Classic Traction Bars
TBP Long Travel Radius Arms
WH 3 1/2 in Rock Crawler Coils and 3 1/2 rear leaf springs
James Duff Extreme Front Coil
37-12.50R16 ND Iroks mounted on Cragar Soft 8 steel wheel w/ matching spare
Driveline
ATK Ford 351w roller motor
Ford Motorsports Ceramic Headers w/ stainless steel 2 into 1 exhaust
Ford Explorer Serpentine Set Up
Fitech Fuel Injection ( Holley 650 included also, truck was built to run either EFI or carb with very little change over)
Champion Radiator with Ron Davis Shroud
Both Fitech electric fuel pump for EFI and Carter 4070 electric fuel pump for carb installed on truck
Summit Racing HEI Distributor and Ford Motorsports Plug Wires
C-4 transmission with Hughes Performance Torque Converter and Deep Trans Pan
Transmission has two external coolers since radiator trans cooler couldn't be used
one is equipped with fan for extra cooling when off road.
Dana 20 with WH Extreme Rear Output Assembly
Tom Woods Driveshafts
Body
Entire front end all new sheet metal
Kick panels, rockers and pillars are new sheet metal
Both floor pans and rear floor are new sheet metal
New doors with Scott Drake Vent Windows,regulators, latches,etc. are factory
New rear quarters
New tailgate w/ new latches,hinges,support cables,etc
TBP Fender Flares
PNW Bronco upper and rear quarter panel guards
Bumpers are custom made included are Hi Lift Jack,Hi Lift Stabilizer Plate and five gallon jerry can
12,000 winch and remote control
Rocker guards are custom made
TBP Six Point Family Cage w/ additional modifications (tied into frame)
Rampage Soft Top
Interior
PRP Seats Front and Rear
Three point seat belts front and rear
WH Lockable Console
Tuffy Underseat Lockable Storage Box
Tuffy Rear Speaker Enclosures
Kenwood Stereo with Kenwood Speakers in front and rear
12 volt and USB charging ports in dash
Winters Shifter
JB Fabrications Twin Sticks
Auto Meter Z Series Gauges
Summit Racing Tilt Steering Column
Grant Steering Wheel
Chevy upgrade rebuilt heater box
American Autowire Wiring Harness
Truck is set up for second battery, but needs second battery and isolator
Haltron Fire Extinguisher in front , large Co2 mounted in rear on cage with quick release
WH Two inch body lift
Misc.
Head lights are Truck Lites LEDs
James Duff LED rock lights under truck on roll bar tie ins, two also installed under hood for lighting engine compartment if needed
Front and rear LED lights for off-road
If you have any questions send me PM. Serious inquiries only, no tire kickers please. Asking price is $27500.00 . Local pick up only buyer responsible for arraigning and paying for shipping. For some reason I could only upload one photo to this post. My garage has additional photos in it of my rig.
Frame
Driveline
Body
New rear quarters
TBP Fender Flares
Rampage Soft Top
Interior
WH Lockable Console
Winters Shifter
Misc.
