Good point Mike. Always check for the old "Pull For Heat" condition!
But huskybul, if that's not it, sorry to hear you're having trouble with one of our fans. Since you verified the direction of the motor spinning, give us a call on Monday to see if that's consistent with what we expect.
One of the guys can test a motor there as well, but that will only tell us what that particular motor is doing, and not that it's the way they were originally. Since it's the Blaster kit with the new squirrel cage too though, perhaps the cage is what's backwards and not the motor.
Someone should be able to verify that our supplier is shipping the correct ones.
If it turns out to be an incorrect cage, it looks like there's one more aspect the packaging guys are going to have to look at when putting the kits together!
I don't think they would have noted the different orientation of the vanes just off-hand. Would have needed to study them more closely specifically looking for backwards cages.
Guess it's time to go to squirrel chasing class. Comes right after wild goose chasing class..%)
Good luck.
