- Jun 26, 2023
- 43
I am wanting to make a similar roll bar. What dimensions did you use? Do you have any recommendations?Started roll bar and seat belts. Gonna finish tomorrow
Yes I was wondering where you found the pdf for centech harnesses online? I've got some wiring issues I need to address.ThanksRealized today, that since I have been running a HEI distributor for probably 8 years now, that I didn't need and probably shouldn't still have a Ford starter regulator or a ballast resistor wired into the system....managed to find the original Centech harness instructions online for the harness I installed late 90s, and when switching to HEI and 1 wire alternator and such, I just didn't delete a lot of things. It's been my project the last few months to clean all that wiring up. Funny is that it runs just fine with all that extra stuff cobbled together.
I may gain power just from the weight savings of all the needless nonsense I have been taking out the last few months....has to be at least a 3 second gain in 0-60
What kind of paint are you using on your axles and the bottom of your tub?I have not started yet, but I will be cleaning up my D44 to get ready for some paint. Then will be installing the WH disc brakes.
Thank you for your service and enjoy your home time!Just bought a bunch of parts. Roll bar, Tom's leather seats, and some shoulder belts for the beast so I can actually get it inspected and be able to legally drive it when I go home on leave.
Do you have a bulk head in yours. I just fabbed it on the fly. I can use it with a half cab or full top. Wasn't that hard. Just took a little time. If you need angles and dimensions let me know. Just trial and error.I am wanting to make a similar roll bar. What dimensions did you use? Do you have any recommendations?
It's either deep water or deep mud up here, diff and tcase breather all go above the brake booster than loop down. I'm currently trying out a new tractor grease to see how it does. The red and tacky doesn't fare well. Spindle is full of grease and I generally coat the hub pretty good. If pulled the cover a couple times after these deep crossings with nothing inside. Thanks, I need to get someone out there with me to take pictures!Is water crossing a regular occurrence? If so, do you do all the usual things to minimize water intrusion?
Extend your vent tube up into the engine compartment instead of just relying on the frame height (based on the picture) alone to keep water out.
When redoing the wheel bearings, pack the spindle completely.
Yes there are seals back down there by the u-joint, but they aren’t really all that great at keeping water out.
Best to pack the spindle with grease completely.
The wheel bearing seals themselves are pretty good, but make sure to coat the entire inner hub surface with grease. You don’t want to pack it necessarily, but definitely coat it.
And then finally, do what you can to seal the locking mechanism itself.
In addition to the rubber O-rings, maybe it’s time for some silicone sealer? At least between the hub and the hub-lock bezel.
And when you put your new hubs in there (unless you’re able to fix the existing ones?) put some thicker grease on the knob O-ring.
That should at least give your differential a fighting chance.
Speaking of the differential, did you pop the cover and drain everything out and replace the oil?
That used to be considered standard practice after every trip that involved water crossing.
Great picture by the way! I know we like to see more of the bronco for Calendar shots, but this would be a great one for the “off-road“ calendar.
That Bruggy is awesome. I have a similar plan for a frame I have lying around.Jack ola....other than put the trickle charger on the Bruggy. Taking it to a car show next weekend. I think I am going to bolt on the 16x38.5x15's to make for a fun back country gravel road drive. The 37's are ok, but I want to roll up and make statement.
And found a cool shirt.... sort of Bronco related. https://shop.prorodeo.com/pro-red-wright-and-broncs-unisex-short-sleeve-t-shirt/
Ok, so it at least says Broncs.
its a chambered versionWhat model Thrush muffler?
Friend of mine, cut these out on his CNC
They are only 20 inches tall. I need to see if I can get some big ones.Those are super cool. Would look great on a shop wall
exhausted......
