Rear turn signals. No marker lights or front turn signals
phred
Earth
All original 75 ranger. Front park light work. Rear turn signals work. No marker lights or front turns. Ground? Could it be in the column?
Viperwolf1
electron whisperer
Try the hazard lights and pay attention to the indicator lights in the cluster.
phred
phred
Earth
Thanks Phil. Hazards work. Odd now the ts
work as long as long as the park lights are not on. Still no marker lights. Both indicators in the cluster flash with hazards and ts.
Viperwolf1
electron whisperer
Your turn signal switch is good if the cluster indicators work. Bad grounds at the front turn lights. Those grounds are shared with the front side marker lights.
phred
phred
Earth
Thanks Phil. I'll check them all again.
