Well that sucks. I expected some hiccups along the way but not this.
I just finished installing the kit myself right off the shelf for an install video I'm working on. I honestly didn't have any issues. You can imagine my shock reading this so let me see if I can help.
1974 Bronco
351W
AOD
Drake ceramic bronco shortie headers
I didn't have any slip fit issues. With that being said it doesn't mean we're perfect. Not even by a long shot. Here is what I know. Occasionally when the tubes are expanded on our exhaust bender the seam can cause a high spot and needs to be tapped flat with a hammer right on the seam until the tube is round again. With that being said every expanded joint is tested when we build these kits. We try to expand them so they slip in with no issue but fit snug to prevent exhaust leaks. The front of the head pipes and the rear of the Y pipe are designed to be expanded for a snug fit but slide inside of other tubes not over them. This is where you may have to tap that seam. Again, this is not normal but I can't say it won't happen. The two anomalies we cannot control is the drake collector adapters and the mufflers. Some are oval or a little out of round causing a fight when trying to slide our tubes into them. We have found that the Drake collector adapters are pretty consistently oval shaped or out of round. That doesn't mean we didn't screw up. If you have some calipers handy, let me know what the OD is and I'll check the ones at the shop and see if we over expanded yours.
Where the two head pipes meet up to the merge pipe it is best to keep all the joints loose enough to allow the merge pipe to line up. With the 3 speed EB trans you should have plenty of space to move the pipes into position however with a 351W the passenger side head pipe will be close to the trans crossmember and need to be slid down and out of the Drake collector adapter so only 3/4 - 1" of the flared end is inside the adapter. If it's slid in more than that you will not be able to get the Y pipe slid over it. Also make sure you keep your collector adapter bolts nice and loose on the passenger side until the Y pipe is on. If the nuts are threaded on too much it won't allow the collector adapter to pivot downward enough.
Please send me pics of your progress. You can even send me video at
monstermikeduff@gmail.com
I'm especially curious about the dent you are referring too. It's not impossible we let a pipe leave with a dent but it's also possible it was damaged while being packaged and/or shipped.
Again, I must remind everyone there is going to be some trials and tribulations when a new product comes out. We do our very best minimizing issues before our customers get the opportunity to buy them but this is a complicated exhaust kit with several processes and procedures. There is bound to be some issues along the way that we are more than willing to fix and help you with.
MM
