New Bronco Project
mbills8778
Double Oak
I just acquired a '73 Bronco with an inline 6 with a 3 speed transmission. Wanting to swap the engine out for a 302. Will the existing transmission bolt up and work, or should I replace that too? If replacement, what would you recommend?
Superwoody
Skyline
Did the 6cyl come with a auto option. I just haven’t seen one. I’d go explorer swap with auto and everything fuel injection to the 4R70w. They are dirt cheap right now until they start drying up.
M
mbills8778
Double Oak
I assume it's still carrying the stock c4 transmission?
if that's the case you'll have no problem, the 302 was an option for that year and will work fine with the C4.
SHOULD you upgrade the transmission? depends.
some people will tell you to swap that out for a 5-speed while you're doing the engine swap anyway. NV3550 would be nice for a street build (but it's a manual which I like but you may not).
Here's a guide on this site to peruse:
http://classicbroncos.com/tech/early-bronco-transmission-guide-automatic-options
Thanks for the information! My preference is a manual transmission so the NV3550 might be the choice. There's a lot to consider!!
Skiddy
no auto option, congrats on the new bronco, got any pics
welcome to the site.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
He said three speed, not C4. C4 never came with an 6 in a Bronco anyway.
6-cyl transmission is shorter than the V8 due to the longer 6-cyl engine. If you bolt the V8 to the 6-cyl transmission, you'll have to cut into the firewall to get it to fit. Get the V8 transmission and adapter (maybe $100 used) and do it correctly.
M
mbills8778
Double Oak
Here's a few pics of our project, affectionately known as Dusty at this point.
M
mbills8778
Double Oak
Thanks! The door posts are really the only problems. PO replaced/repaired a bunch of the other stuff already. Problem is the quality of those repairs, don't think he was much of a welder!
LUBr LuvR
Congrats on the new ride! Love the custom e-brake on the front tire ;)
stout22
Athens, AL
Congrats on the Bronco!
6 cylinder to V8 will require V8 engine mounts, V8 3sp tranny adapter, possibly radiator replacement with core support mods.. Not sure what I'm missing on the list.
