Rolling Chassis - what's it worth?
NCBeachBronco
I know where a stock rolling chassis is with V8 (not sure which one-prolly doesn't matter. It's sitting uncovered so most likely is a milkshake anyway), 3 speed, Dana 20 tc, Dana 30 front and 9" small bearing rear. No title.
He was asking $1000, but now says make an offer. Any idea on ballpark value?
71Broncitis
With no title, that's more than I'd pay.
Frame: $300-500 if solid
D30: nearly worthless
V8 with unknown history: $250-350 if not seized.
3 speed: nearly worthless
D20: $150
9" SB: $300
$750 would be my top offer, and only if I needed most of those items.
$350-450 if you plan to part it out and sell the parts individually.
Sent from my XT1254 using Tapatalk
NCBeachBronco
NCBeachBronco
Perfect response!
That's what I needed to know
Thanks!
A guy that works with the owner said to offer $500 and I'd most likely get it.
The no title frame is the scary thing. Build a project on that and try to get a title only to come back with the prior owner wanting it back, you just built him a great project and you are out everything.
The 30 is not worth it. Nobody wants the small bearing 9" That's not where to start a project. The one reason anyone has one is because it came that way. Muck like a dana 30 or a stock 3-speed. Of the stock options, it is the least desirable.
The engine if not stuck is a $100 core. Does it have the early bronco oil pan? That might be worth $50.
So you are looking at an oil pan and a Dana 20 transfer case. $200 tops.
Rustytruck
Might be worth more as a body holder while doing a frame off on your project Bronco.
sykanr0ng
/\/\ Turn it into a rotisserie, no sense using a titled frame that could be put on the road for one.
The only other use would be patch pieces for a bent or rusted away frame that was titled.
Around here people try to give away the D30 and 3 speeds and often end up scrapping them
fatboy
Glad to be here.
New Hampshire
Jeep guys will buy the dana 30 sometimes. That is who I sold my last one to. I have more 3 speeds than I care to admit. I am a $200 guy if the frame is decent. If it is exceptional maybe more but I doubt it if it has been sitting. In NH I can have a frame VIN checked before I go down the "build road".
sykanr0ng
Run the VIN before you buy, if it is stolen you don't want anything to do with it.
71Broncitis
I've sold a bunch of SB 9"s to Jeep, Ranger and street rod guys. Not everyone cares about BB as much as Bronco wheelers.
