WASP1971
Beautiful. I'm glad you can dedicate some time to it now.
good change, I'm starting my swap in two weeks. Interested to see what you do with a shifter, wiring and engine fitment. Good luck and great build
I got as much as I could from the Explorer I might need including the shift cable for the trans and throttle cable. EFI Guy will be taking care of the wiring for me. Get the EFI engine out isn't that bad. Pretty simple job. I started with all the wiring then went after the engine/trans. Hope your swap goes smooth.
After the weather holding up the delivery of my Duff Heim steering I finally got it put together and installed. Also got a 17" Mickey Thompson wheel in for a test fit. Everything clears with room to spare. Have some tires on the way and should have them mounted up by Saturday if all goes well.
