Mocking and installing hydraulic clutch for ax15. Bought special rod end for late model f350. Modified length with sleeve. Mocked up hydroboost fire wall mount a clearanced it for reservoir. What I did not realize is the clutch pedal is the same as a brake pedal with a welded bracket. I just removed it and re drilled hole for bolt.
Fired new motor up this weekend. Other than dizzy wires not counter clockwise and steering pump hose (braided) came loose shooting fluid every where, it was all good.
Thanks JG for the lesson on how to correctly make braided hoses....
