Some info: 68 Bronco, 289, original 2 barrel carb, np435
Problem: running rough at idle. Smooths out some at higher rpm, but really it just mask the problem. This problem started right after a steep ledge climb.
Stuff I have checked:
- all plugs look great and I have spark all plugs
- for some odd reason I have about 3psi pressure at the carb manifold vacuum port instead of vacuum!
- I do have vacuum at the manifold, but only about 15 because it's running rough.
So, why would/could I have pressure at that carb manifold port instead of vacuum?
Thanks,
Tyler
Thanks,
Tyler
