jimmy69
I partially rebuilt the suspension within the past 12 months, I did not like the results. That said, I ordered a complete James Duff 6 inch suspension. My loss is your gain. The parts listed below have probably less than 100 miles as I haven't been on the road much, complete restoration in the works.
Everything is negotiable- local pickup only. Make your offer reasonable, we both know the prices.
Ripped out whole suspension- here we go.
Deaver front coil springs - immaculate condition- I think from WH, less than 50 miles
WH tie rod and drag link 3 way adjustable - surface rust, less than 100 miles
6 rancho shocks- dirty but otherwise solid, 1 year old, 100 miles maybe.
Addco front sway bar kit- installed for less than 35 miles, immaculate
Rest of original suspension parts in varying condition but useable
Chrome vacuum brake booster with MC- replaced with hydroboost
Ps pump pulled at that time for hydroboost.
Mechanical fuel pump
Next week I'll be pulling out the msd coil, MSD distributor and bolt on EFI. Replacing with Fitech 800hp setup.
Next few weeks, changing out 5 MT 15" x 12.5 chrome mags, spare new in box
For those wanting to go power step, I've got a set of amp powersteps for hummer 2- cut to fit bronco. Will need to fabricate brackets to frame but it's going to be a good deal. Basically new in box.
Email me and I'll send pics of whatever you like. I'm off this week so if you want to come by, we can do that too.
Jimmy
Jimmy
