1977 bronco. 351w with an rv cam, edelbrok intake, new headers, new holley carb. Great running motor. C4 trans. Dana 20 with a twin stick conversion. Power disc front brakes. Power steering with new Saginaw pump and bracket. New rear drum brakes. Drives straight and stops even with no pull.4.12 gears, stock posi in rear. 35" tires in great shape 15"x10 wheels. 5" lift with dual shocks front, single rear with new leaves. Daul tanks. Exterior and interior was redone about 6 years ago. Kept in a garage all the time so its in great shape. Cowl hood, fender flares, front and rear bumpers are new. Interior is bed lined. Buckets with original recovered bench in the rear. Spare tire mounted on the rear bumper. The diamond plate isn't covering rust. It's clean. Older soft os in good shape, have the hard top also. Has a sport cages, although a full cage can be purchased from my brotherif wanted. I'm posting this for my sister. Her contact is 2512300720. Leave a message if you don't get her. She works crazy hours.
