Here are a couple of pics of what I got accomplished last night. Started disassembly getting ready to start all my installs
Here is a pic of the bronco after I did some rearranging in the shop to fit the bronco in so I can start the efi install
Hey JDJ, What's that car under all the junk?
Well.....here is the possible problem.
First take a look at this web page link (fordfuelinjection.com): http://www.fordfuelinjection.com/Inject_your_horse2.pdf
After you get that page loaded, go to page 5 of 9. That is the first page about intake manifolds. In the pic of the two lower intakes, one labeled good has a threaded hole for the Air Charge Temp Sensor, the other is labeled bad and has a boss that could be drilled and tapped for the Air Charge Temp Sensor.
The lower intake that came on the explorer engine that i got, doesn't have the boss on it at all.
Here are some pics:
I have a mass air meter off of a fox body mustang. I also have 19lb injectors from a fox body mustang that I plan on using
