Harbor Blue Build Thread
JeffG
San Antonio, TX
Thought I would start a build thread to document my progress, or lack of. I can't believe I created my profile in '04 and I have less than 100 posts.. I'm more of a researcher than talker :cool:
Lived in San Antonio since 2000 and have owned a '69 since '98 and have been a part of the Lonestar Early Bronco Club (LEBC) since around the same time. I bought a crawler/trail rig project in around '09 and had fun with that for awhile and sold it to a fellow LEBC member in '14.
I purchased this current build in I believe '13 and it sat mainly due to space and family commitments. I had some initial pics of when I bought it but I lost a phone that had all of those on it %)..
I will attempt to compile the pics I can locate into chronological order in order to get caught up to where it sits now.
JeffG
JeffG
San Antonio, TX
Couple pics of '73 crawler mentioned above.
JeffG
JeffG
San Antonio, TX
I took as much of the original hardware I could and used a wire brush on end of grinder to clean up prior to sending off to be plated. It has been nice to work with clean factory hardware.
Before and After pics.
JeffG
JeffG
San Antonio, TX
I hope to be able to locate the pics when I brought the bronco home, but if not I will just have to make due with the build up process. The tub was very rusty, so I was lucky enough to pic up a very clean tub from a fellow LEBC member. Looks to be an earlier model based on the holes in the firewall for the wiring harness routing.
I did manage to pick up a set of 15 x 8.5 slot mags! Will be polishing these up later on in the build.
JeffG
JeffG
San Antonio, TX
Some random pics of parts clean-up along the way.
JeffG
JeffG
San Antonio, TX
Dash pics. Sure with PO would have done a better job of cutting out that radio hole. Just add it to the other metal work repair list.
JeffG
JeffG
San Antonio, TX
Couple pics of the frame and VIN. The reason I listed this build as a 197# is due to the frame and title being a 1977, the tub being pre-1972 or so and having a mix of parts from other years as the bronco was incomplete when I picked it up.
JeffG
JeffG
San Antonio, TX
Frame clean up complete. I decided on the KBS Blacktop Chassis Coater and I have to say I am pretty impressed. You can brush or spray this on, so I decided to go the brush route.
You can see some slight brush marks in the sun, but once everything is bolted on it won't be a big deal at all. Fingers crossed this stuff holds up as advertised.
JeffG
JeffG
San Antonio, TX
Running brake lines with some double line clamps I purchased off eBay. I plan on using larger metal tubing to run most of the fuel lines as well for a clean look.
JeffG
JeffG
San Antonio, TX
Cleaning up some of the engine parts. My '69 has a 5.0 from an '89 mustang couple with an AOD, 4.88 gears and currently 33" tires. I plan on building this bronco close to stock with the 302 and 2 barrel. Came with a C4, so will keep it mild with maybe a 1" or so lift and 31 or 32" tires.
JeffG
JeffG
San Antonio, TX
Mounting the radius arms to attach the D44. Love the plated hardware mentioned in a previous post!
chuckyb
Looks great! What kind of plating process was used? Any tips or recommendations ? I want to do this with my salvageable hardware and brackets.
QUOTE=JeffG;3019516]I took as much of the original hardware I could and used a wire brush on end of grinder to clean up prior to sending off to be plated. It has been nice to work with clean factory hardware.
Before and After pics.[/QUOTE]
JeffG
JeffG
San Antonio, TX
They were plated with clear zinc. Look for a local plating company and they will be able to hook you up.
JeffG
JeffG
San Antonio, TX
Replacing floor pans and welding up holes that will not be needed.
JeffG
JeffG
San Antonio, TX
Using KBS Motor Coater Engine Enamel to paint the engine and other components.
JeffG
JeffG
San Antonio, TX
The tub I picked up was originally Boxwood Green. However, I'm thinking of going with Bahama Blue as my '69 was also Boxwood Green. Back in '99 I had it painted Land Rover D90 yellow, but now wish I would have gone with an original EB color.
