I pulled the engine out of my 76 lubr and I am just tired of trying separate the block from the heads and manifold. Everything is breaking, and the bolts are just stuck beyond imagine. If I had maybe 3 months to waste on just breaking down the motor, I might be able to finish. Needless to say, I'm going to trade this motor in on a rebuilt motor at City Motor Supply in Dallas, Texas and save me the frustration.
So, here is my dilemna................what engine do I get? First, I'm not interested in cutting the hood, so I guess a 351W is out of the question. I'm currently sitting on a 1" body lift on 31x10.5x15s. I'm basically making this bad boy a street crawler with light camping. After what I have been through just doing a sheet metal swap, I'm NOT going to damage the body. I'm just at that point where I'm feeling a bit overwhelmed, and I think I'm ready for easy peasy. I'm keeping the original C4 transmission and I am looking for something that won't need a huge amount of mods. I want to basically bolt it up to my C4 and VROOOOOM. A buddy of mine says to stay flat tappet for the lower RPM benefit. Oh, I am staying carbuerated so full disclosure. Which should I purchase? Thank you sooooo much in advance.
Here are my choices from City Motor supply:
Guide:
CUBIC INCH
LITRE
YEAR
CYL.
BORE
PARTNO.
302
5
68-74
V-8
4
7812
302
5
75-79
V-8
4
3/8 Auxiliary Bolt Hole - Right Front Pad on Block"
7814
302
5
79
V-8
4
E.E.C. Sensor Rear of Block
7815
302
5
75-81
V-8
4
Heavy Crank - Dip in Block
7816
302
5
81-86
V-8
4
2MAE Light Crank - Dip in Block or Oil Pan
7826
302
5
82-85
V-8
4
H.O. - Flat Tappets
7827
302
5
85-91
V-8
4
E.F.I. - Roller Tappets
7828
302
5
85-86
V-8
4
H.O. - Roller Tappets
7829
302
5
81-88
V-8
4
E.F.I. -Hydraulic - Flat Tappets w/ Knock Sensor
7880
302
5
85-91
V-8
4
E.F.I. - Roller - w/ Knock Sensor 15426378 Firing Order
7882
302
5
87-00
V-8
4
H.O. - Roller Tappets - w/ 13726548 (351) Firing Order
788
Guide:
CUBIC INCH
LITRE
YEAR
CYL.
BORE
PARTNO.
302
5
68-74
V-8
4
7812
302
5
75-79
V-8
4
7814
302
5
79
V-8
4
7815
302
5
75-81
V-8
4
7816
302
5
81-86
V-8
4
7826
302
5
82-85
V-8
4
H.O. - Flat Tappets
7827
302
5
85-91
V-8
4
7828
302
5
85-86
V-8
4
7829
302
5
81-88
V-8
4
7880
302
5
85-91
V-8
4
7882
302
5
87-00
V-8
4
788
