Explorer swap flywheel
onpier55
Roseville Ca
My bronco came with a 1974 302 and 1969 351w. Can I use the flywheel from them to go on the explorer motor?
Karl
sykanr0ng
Karl
No.
The imbalance for pre 1981 302 engines and for all 351W engines is 28 ounce.
The imbalance for newer 302 / 5.0 engines is 50 ounce, which would still be 22 ounces out of balance with the earlier flywheel.
onpier55
onpier55
Roseville Ca
Thanks, I’m glad I was reading through the toms bronco parts catalog last night and read there was a difference. Well now I need to find the correct flywheel. Ugh
It can work, if you have the right flywheel with the right pattern drilled into it.
The Explorer was never offered with a flywheel, only a flexplate. Automatic transmission only.
onpier55
onpier55
Roseville Ca
If I went to the junk yard to source a 50oz flywheel, what vehicles should I look at? Short of just buying one from one of the venders which I may just do. To save time.
onpier55
onpier55
Roseville Ca
What vehicle could I source a 50 oz flywheel from at a junk yard. Short of buying one from one of the venders, which I may do, just to save time.
sykanr0ng
'82-'96 ('97?) F Series trucks with a 5.0L engine, you can also get those through a regular auto parts store.
Mid 80's is better. has the old style clutch. I don't think the later flywheels are all drilled for the old style clutch.
Has to be a truck flywheel. Car (Mustang) is too small.
904Bronco
San Martin, CA
My experience has been that new replacement flywheels are Chinese made.
Napa's said that on the flywheel. O'Reilly's is made by Power Torque #NFW1128. It says made in China on the box.
The last one I bought was from WH's, it was American made. But that was when Mark Beck worked there... so that would have been 8 years ago.
onpier55
onpier55
Roseville Ca
Looks like this is the remedy. Thanks Doug.
onpier55
onpier55
Roseville Ca
It arrived, now just have to find the time to install it.
sykanr0ng
Fords are pretty simple there; you use a manual transmission starter with a manual transmission or you use an automatic transmission starter with an automatic.
Size of the flywheel does not matter, the bellhousing corrects for that.
The newer year model mini-starters are really good.
