- Joined
- Nov 28, 2001
- Messages
- 10,102
Andrew Norton (bajabronco) and I had the pleasure of spending some time on Friday at Barrett-Jackson going over the first production/prototype/Shelby Bronco in the Gateway Broncos booth. We met the current owner, Seth Burgett, and were also thrilled to meet Vinny Yakubanski, the second owner. Andrew and I had corrresponded with Vinny about the Bronco back around the turn of the century and it was great to finally meet him and see the truck for the first time.
Here are the four of us:
Andrew is a real detective on this historical stuff and he quickly found some of the oddities on this special truck. Look closely at this Sport emblem: it's actually two pieces - the Sport emblem is carefully fit around the Bronco script. And look at the top of the Sport emblem - the 'turrets' are carved out and separate. On the production piece, there are just cuts in a solid piece to give the illusion of the turrets.
As an early truck, you would expect this truck to have an eyebrow grille, but this one doesn't. In my article many years ago, I surmised that perhaps this truck was used as the development truck for the Sport trim package and it appears this was probably the case. Andrew noted that the grille trim for the Sport package wouldn't fit well on an eyebrow grille so the grille was probably changed for this effort at some point.
Another interesting item is the two piece hood latch. The bottom has a small bend in it for your fingers to catch but it's pretty obvious that was sufficient and the pull we're all familiar with was instituted in production.
Notice also in these pictures that the letters on the grille aren't production Bronco Sport letters. I found some similar, but not identical ones on other Ford cars of the era at the auction. Perhaps another enthusiast more familiar with that detail could tell us what vehicle they're from.
Andrew hard at work:
Here's another little detail - the two connector plugs in the harness coming out of the angled portion of the firewall instead of on the front near the throttle linkage.
Remember those little pieces on the cowl support that folks were wondering about a few months ago? Mystery solved - it was as some surmised - used to hold the bottom of the hood prop rod.
Around back on the tailgate, we found a very different license plate holder without the usual shape and form of the production unit:
The top of the cowl on the driver's side underneath the airbox has an additional rib that we think wasn't there on the production units?
The passenger's side cowl box is a prototype fiberglass unit that is noticeably different from the production plastic piece and the wire mesh in it is a key piece in a hunch that I have regarding the engine in the truck.
I'll continue more in Part 2 as I have time.
Todd Z.
Todd Z.
