Fuel line hose size?
gnsteam
Lincoln NE
I'm out shopping with the wife and I need to stop and pick up some fuel line hose. What's the standard stock size of the hose used at the fuel pump and tank selection switch.
savage
Bronco Nut
Renton
I have read that 5/16" is what they came with.When I redid my nylon line with metal fuel line I measured the line and it was 3/8",so I think it depends on what is stock and what has been change through the years,fuel line is cheap buy both.
RODRIG3911
Tucson
3/8" is what i used..... Buy 3/8" brake line instead. It's cheap and lots better. You can bend it and mount it to your frame with metal clamps. (use the ones with rubber over the metal)
cs_88
When I replaced mine it was 3/8" as well.
gnsteam
gnsteam
Lincoln NE
Thanks to all who replied. I bought 3/8" and indeed that is what I found when I got home.
Thank you!
