Bringing parts below to Super Celebration. Leaving San Diego and traveling along I-40 to Nashville beginning 7 Apr. May stop and meet you if the price is right!
Recently did a big 3 swap (engine, tranny, t-case and have some old (and brand new) parts. Prices are firm unless you want to come pick up - then we can deal. Shipping is extra.
1) $70- BC Broncos Multi Steer Bracket installed but no miles (few scratches)
2) $20- Wild Horses Poser Steering bracket- I got a bit anxious and cut it to fit a Saginaw pump (dont think I needed to in the first place but oh well)
3) SOLD $10- Brand new starter relay (solenoid)
4) SOLD $5- used starter relay (solenoid)
5) SOLD $7- 351 alternator/ power steering adaptor bracket
6) SOLD $7- 351 alternator adaptor
7) $20- used (great shape) motor mounts
8) $50- March Performance under drive crank pulley
9) $10- brand new voltage regulator
10) SOLD $5- used voltage regulator (works fine)
11) $40- used alternator 60 amps (works perfect)
12) SOLD $30- brand new 351 smog pump delete kit
13) SOLD $30- brand new A/C delete pulley (still in box)
14) $5 (each) 2 thermostat housings installed but never run
15) $115 Brand new Lokar C4 kick down cable
16) SOLD $150- aluminum Champion radiator
17) SOLD- $5- C4 shift linkage (extended 2" due to body lift)
18) $8- twin stick shifter boot
19) $10- hood shocks. will not work with steel hood but should work with fiberglass (no mounts- just the shocks)
20) $5- replacement wipers.
21) $5 stock power steering pulley (V-belt)
22) $10 March performance power steering pulley (serpentine belt)
23) $10 Serpentine belt (65 7/8") part # K060653
24) $40 Brand new custom chrome radiator hose kit
25) SOLD $10 billet aluminum alternator fan
26) $5- rear reflectors (and 1 chrome trim ring)
27) $40- Attometer Arctic White Speedo 3 1/8" https://www.autometer.com/3-1-8-speedo-120-mph-w-trip-mech-arctic-wht.html#s8wKYm5DX8zh4KKt.97
28) $75- WH Fan steel fan shroud (with 2" body lift adaptor) https://www.wildhorses4x4.com/product/Fan_Shroud_V8_only/Bronco_Aluminum_Radiators
