DanWheeler
Thanks, Steve. That will be the plan.
That said, I just got back from a test drive after really dialing in the shocks at a lower ride height and I think I'm going to hold off until the weather turns before pulling it apart. It's pretty drivable down lower. Still some brake dive but much less.
Only problem is that the ride is pretty firm in the rear. The older ST struts I have, want to be sitting right in the middle of the shock length so 8" of chrome on s 16" shock. I've got 4" showing. I talked to ORI and they said something about the STs sitting on or in the oil that causes a firm ride. I need to order STX or send these in for upgrade. The STX can run at any ride height due to some valving changes.
I Gotta one of those dual-fill nitrogen hookups and something with a long hose so the bottle can stay on the floor. I'm going nuts trying to hold that heavy bottle up, connect the shrader fitting, open the shrader fitting, open the nitro bottle then turn the regulator handle. I need 4 more arms for all that. The air shocks really play off each other. It'll be nothing, nothing, nothing then go over to the other side, put a little air in then suddenly it shoots up way past ride height. Ive been going incrementally on each side so dual fill would be great to bring one end up as s pair.
Here's a pic at lower ride height. Doesn't look as fun =D
