New 74 project
ehumaui
Well back to the 4wd crew, jumped at a bronco for a good price. Needs work, but solid body.
Wish me luck. New neighbors are going to hate me.
Rc
E
ehumaui
It's done. Here it is.
sprdv1
REBEL
Congrats man. Looks like a solid foundation. Look forward to the progress
jmangi62
Looks like a decent starting point for a nice build,my boy would love you're lowered half cab,very nice.:cool:
E
ehumaui
Tear down is going slow. Engine and Trans out. Pulled Trans out with torque converter still attached to motor, bolts frozen. Motor out, it's toast. Worked on removal of dana 44. Noticed no axles, ton of mud in tube. Pulled cover and blown gears and full of dirt. Must have been a mud runner and 2wd for a while.?:?
E
ehumaui
Picts of axle
E
ehumaui
Going with the ax15 and dana 20 combo. A little confusion on the correct twin stick model. Shout out to JB who is going to make a new outer.
E
ehumaui
Axle jack stand. I guess I watch Ian to much on Extreme 4x4. Found out if the pumpkin is off center, it gets a little tippy. I off set it and tack it to the base. Even added a pinion support.
E
ehumaui
Frame stripped, rust stop and painted.
E
ehumaui
With my back aching and almost dropping body again, I purchased a gantry to put body on.
E
ehumaui
Painting parts when the sun comes out.
E
ehumaui
Both teas losing, not raining so I lifted body back on. For some reason I couldn't find the sweet spot to lift sraight up. Took a couple tries. Body back on.
Note to self, Dont lift heavy things when on knees......back is killing me.
E
ehumaui
Little work done today. Rear axle mounted. One duff arm intalled. Forgot how I hate c bushings and caps!
broncoitis
Nice job so far! Gonna have to keep an eye on this as best I can. Good Luck!
E
ehumaui
Got to play with a plasma cutter at jg house to remove brackets. Wow that was fun. Also got to install front suspension this weekend. Just need drop pitman arm. I guess I should have waited to drop body back on before I welded brackets on. Was pretty hard welding on my back.
E
ehumaui
Custom brake line with eastwood flaring tool.
E
ehumaui
Found used rebuilt 351w. PO left it out side. Some water got inside. Surface rust and minimal pitting in couple cylinders. We will see what the shop says. 3m and wd40 and most came clean.
