EFI Users
tatersalad
No but it looks like it would work on an efi system that needs a halls sensor to fire the coils.
Amac70
ME
haven't used the msd but have holleys dual sync distributor will do the same thing.
markw
Okay, this is all new to me. sykanrOng what can you tell me about this technology? I'll do google research as well! Thanks, Mark
nvrstuk
The 64bituning just sends a signal from the rotation of the cam and sends it to whatever system you are using for spark.
I use EDIS which is Motorcraft on my stroker. I used a Windstar cam synchronizer "shaft" and it is correctly spaced on my 351W block so it fits the oil drive gear etc. Essentially all these things do is send a synchronized signal to whatever your ignition system is.
markw
Okay, that is the same information I just got from EFI Guy this morning. Looks like I'll be staying all Ford. What coil packs are you using/recommend? Thanks!
sykanr0ng
Either the stock Explorer coil packs or '96-'05 Dodge Neon (with some work) are good choices.
The Explorer uses a special Ford type of spark plug wires, the Neon packs use standard HEI style spark plug wires and the wires come out the sides.
There is no need to go aftermarket, the OEM coil packs are powerful enough
markw
I think I'll use the Neon coils in order to keep standard plug wires. Thank you!
nvrstuk
Neon...stock style wires..HOT freakin' spark...
sykanr0ng
They use one Neon coil pack (4 cylinder) plus one Stratus coil pack (6 cylinder) on the Dodge Viper.
nvrstuk
MarkW, Garry set me up to go EDIS years ago...all stock FORD Motorcraft parts (although even Motorcraft parts arent like they used to be-but still light years better than most aftermarket for durability and longevity). Only non-Ford part are Neon coils and they are good for 8K rpm so... :)
Over several decades of experience with MSD, their slogan should be "MSD- My Spark Disappeared"...
markw
Great information. Looking forward to the conversion. Thank you!
