msommer001
- Jan 15, 2009
- 370
I was doing some under the hood cleaning and inspection after changing fuel filter and adding some heat deflection sleeves on the fuel line. I have been having some issues off the beginning cutting out under load.
While I was working I discovered the distributor wiring harness was very badly deteriorated and all the wires were melted at some point then covered by electrical tape by the PO.
Can you just replace the wiring pigtail?
If a new distributor is needed, what is the best option? Is it a good time to upgrade? If so, what is he recommendation. I am willing to spend the money on the right options but I am nervous about setting timing.
All other aspect of the motor are stock. 1977 bronco, ranger.
Thanks in advance for all the help and guidance.
