- Jul 11, 2001
- 2,060
Well, glad to hear that. I was thinking it was a optical elision because the first time I used this system on my EB I was concerned about hood clearance.
Now we need to figure out why the pump is not right. If you can take the bracket off and are O.K. with a slightly use one (we used it for testing only)I found one today that I can send tomorrow. If you don't want to take a slightly used one just take the bent one off, hammer it flat and reinstall it with the spacers just to see if that will fix the tilt. I think I can get a diff. offset pulley that might fix the aliegnment and I will send a new one when they come in.
Chuck,
I removed the PS pump bracket and sent it to you today.....it will arrive on Wednesday. You'll be able to tell that it s a little warped and was adding to the misalignment issue. Go ahead and ship me the slightly used bracket today, so I can get it mounted up this week. The offset pulley sounds like a good idea as well and I'll try that too.
