Randy's Ring & Pinion
Search All Bronco Links
  Holley Carb Tips
 Aussie Locker
 C6 203 205 Doubler
 4 Link
 Clutch Replacement
 Early Turn Signals
 C4 Improvements
 Threaded Dipstick
 NV3550 5 spd
Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco FAQ > Brake FAQ
FAQ Tools
Disc Brakes vs. Drum Brakes Disc Brakes vs. Drum Brakes
Pros and cons of both brake systems
admin
05/14/06
Following are typical pros & cons for both disc and drum brakes:
Drums
  • Pro - Less expensive since they're already stock on Broncos
  • Pro - Drums work better then discs as emergency brakes
  • Con - They stop poorly when wet and can get clogged with mud
  • Con - Stopping power can fade with repeated hard braking
  • Con - Larger tires
Discs
  • Pro - More consistant, straight line stopping power
  • Pro - Dissipate heat better to stay cooler
  • Pro - Less affected by water or mud
  • Pro - Easier to maintain and faster to replace pads then shoes
  • Con - More expensive to install (but maintenance costs should be less)
Most people will agree that discs are better than drums. However, stock drum brakes can be effective if they're in good working order and properly adjusted. Typically when people upgrade to disc brakes they're replacing worn out drums, so they see a vast improvement and are quick to credit their new disc brakes. Just keep in mind that when someone raves about their new disc setup some of it is due to simply having new parts.
  #1
AndyR on 06/29/10, 09:01 PM
What are drum to disc parts sources and approx. cost of parts?
How many labor hrs. to R & R ?
  #2
ctkd on 08/06/13, 07:17 AM
Is anybody using a drum frt, and rear with a pwr booster ? My 74 stops ok with 33s just wondered if this would make it stop better?
  #3
swultra09 on 10/16/16, 08:57 PM
so i have disc on the front is it worth disc on back? also is a booster worth the dollars?
  #4
bronconut73 on 10/16/16, 09:01 PM
I like 4 wheel disc but it ain't necessary.
Boosters are nice. Hydroboost is the best and cheapest.
  #5
bugout75 on 11/23/16, 10:23 AM
I was part of a bronco club back when I was a teenager and FINALLY got a chance to get another one. I just picked up a 1975 Bronco and was wondering if some of you may know what ford parts will swap onto these broncos?
Parts such as Disc Brake swaps and power boosters. What other cars will the parts interchange from?
Thanks!!
FAQ Tools
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
Copyright 1996-2018 All rights reserved. Privacy Statement
Page generated in 0.41233 seconds with 63 queries
