Unimog axles (update.. Got it. mog9 build pics..)
Madgyver
Madgyver
Bronco Madman
i wonder who bought it?
attachment.php
NYLES
After doing A LOT of research, I decided to not use the 404 axles in their stock form. I decided to build a hybrid mog/9 for the rear. 9 inch center section with mog boxes. I converted them to disc brakes to avoid the common over heating problem and to provide better brakes. I turned down two stock long side axle shafts to 35 spline and I am running a Strange large bearing center housing with ARB. I am running a 2:47 R&P and then I have the reduction of 2.17 in the portal boxes. Now I can drive over a 5 gallon bucket and not hit it! ;D
Nice! I can clear a milk crate!
NYLES
If any of you are truely looking for a rig like that there is a single rear axle 2.5 ton for sale in Vicksburg MS. Ill snap A pic of that for next time I go by. Not unimog jus a common duce n a half with single Rockwell rear axle. Looks real nice I just cant dream up a use for it.
Back to the program .......go for it Mad!
Talked the Bow girl into snappin a couple pics and sendin em will post em in a bit.
bmc69
I have a complete set of Rockwells..one front, one rear. Was going to do an 'extreme' EB build with them but now I'm just sitting on them. I recently found a '52 IHC 1.5 ton truck that looks like it needs 'em.;D
I need more projects..just like Mad does too.%)
Revelation
Holy Thread bump Mad.
Mog + Bronco, how much more motivation do you need?
Maybe a new assistant Mechanic?
