I have a '76 manual 3 speed in my Bronco, it does have the Dana Splicer driveshaft in it.
Here is my problem...Coming home tonight I noticed when in gear and releasing the clutch I was getting a 'bump' 'bump' which sounded like it was coming from my transmission. The bump got quicker the faster I went down the road and putting it in neutral and coasting down the road the noise stops. I couldnt really feel a vibration like a u-joint does and honestly was worried I have some gears going bad in the tranny. BUT I do have a Twin stick installed in it. After I got home, I locked in the hubs, put it in 4 wheel drive and put my rear end in neutral. No noise...4 Hi or 4 low (with rear end still in neutral) no noise. I crawled under it tonight with bad lighting and shook the driveshaft but didn't see it twist and move like a bad u joint would do but I have no experience with the CV joints. I plan on taking out the rear drive shaft Friday to do a better inspection. What do I need to look for?? Maybe I have something else wrong?? Any test I can do??..And this CV joint looks kinda tough to replace, can it be done with a vice like any other u-joint?? Thanks for any help, was hoping to go mudding this weekend so want to get this right...
