Kalkster73
I just replaced wheel bearings on stock axles ('74 large bearing). On the passenger side, the bearing and retainer pressed on with a decent amount of force as expected. When assembled back in the housing, the bearing OD slide right into the bore and the retainer fit flush.
On the drivers side axle, the bearing slid right on and the retainer took a very light press. When going back in, the bearing OD did not want to go back in the housing. It took several whacks with a dead blow and drawing in with the retainer plate.
Can you confirm this is not right and that the outer race should be line to line or a very light press with the housing?
