I thought this might be good info for others looking to put a 14 bolt in if they are trying to spec out a specific WMS.
Below are several pics showing the hub width differences allowing multiple WMS widths when using the same axle housing assembly. (Update) "Most" hubs, bearings, axles, seals, internal components interchange but brake rotor, caliper and more important, caliper bracket location vary with each hub... and I have no idea about drum fitment issues and who in their right mind would want to use 30# drums on each side when you can use discs instead- right??
All the brake rotor issues are easily solved by calling Shawn at Lugnut4x4 who sells brake systems or components specifically for D60's, 14 bolts and other popular axle swaps. Ruff Stuff has a few options but Shawn can sell you everything you need.. He knows his stuff and his parts are high quality and cheaper than local sourcing...anyway, he can tell you which rotors and brackets can or will be needed to use with different hubs.
I chose weld on calipers again because I'm mixing axles and rotors so I need to place them in a different location than stock for my axle.
Here's some pics showing hub WMS differences. Steve was helping me determine which hub offset went with different models.
13" drum hub
10" drum hub (more rare)
C&C hub
disc hub
Update- the 2 1/2" hub is a WEIRD one. The inner and outer brgs are NOT spaced the same as other hubs at 2 3/8" compared to appr 3". What this does is it moves the outer brg closer to the center (of the axle) and on my particular housing it does two things.
1- it bottoms the outer brg against the taper of the spindle (because of the narrower brg spacing) and doesn't allow you to preload BOTH brgs. Just the inner.
2- it also places the outer brg on the spindle where there isn't any threads so you can't tighten the nut up against the brg to seat it...
I will describe later how I fixed these problems so I could have the WMS I needed.
R
