...offered at community colleges and major universities.
None of the universities I went to offered it - that's why I asked. Not LSU, and not the state university in my hometown. The other was a specialty college - not technical - so of course it didn't.
Japanese cars have about 12 grounds. American cars about 3, now this was 20 years ago when I was in class...
I don't know what US vehicles you're talking about - my '83 Bronco was built with at least 8 ground points; my stock '93 has a dozen.
I do. I still work on them today. So does anyone who looks up their wiring diagrams:
http://www.revbase.com/BBBMotor/Wd
You took some time today to discredit me...
No, I didn't. My previous post didn't take much time, and what I post has nothing to do with your credit. I posted my opinions, observations, and a question.
The dealership where you worked, was it located on Mars?
Now you're discrediting yourself, so don't blame me for it. %)
Stacked grounds is okay for some circuits, not all.
Which ones?
Computers do not like to be anywhere near a dedicated ground...
Odd then that Ford & most other automakers put a major ground point near the PCM/EEC. In that diagram above, G104 is maybe a foot from the EEC; G201 is probably <6". In this pic, G104 is barely out-of-frame at the top center, but you can see the black wires going up to it:
In this pic, G201 is the green bolt below the hood pull:
So: with a factory ground loop, you'd expect all those millions of trucks to have millions of computer & signal problems, right?
...the body shell and it's near zero resistance.
When it's NEW, maybe. But Copper wire has less resistance than steel; particularly after 30-40 years of off-roading. That's why modern vehicles don't use grounding for most circuits. Especially those sensitive to AC or RFI.
Look at a 15 year old side post battery cable. Notice something?
Lots of things - you'll have to be more specific.
I put 3/8 coarse studs in my batteries...
Me, too. Stainless. Then I sold the truck.
...the rubber is hard around the boot...
Not mine.
...the contact area is minimal.
I estimate ~400 square millimeters (including the bolt) for a clean side-terminal; about 700 for a clean top-post. Either type can become filthy & have "minimal" contact area.
The hard boot won't make good contact no matter how hard you bleed the 5/16 bolt.
I assume "bleed" was a typo, but it'll get tight if you clean the battery terminal face, and the groove between the Lead & the plastic lip so the boot has a place to fit into. At least; I never had a problem with it on all the side-terminal vehicles I've worked on.
AC is everywhere in a car, the speaker outputs for the sound system and speed sensors to name a few.
But this thread isn't about the audio system, and early Broncos don't have speed sensors. Certainly not running through the coolant system. So I don't get your point. We're talking about galvanic corrosion due to the power distribution wiring, and you brought up ground loops. Why are you now talking about speakers & sensors (that most eBs don't have)?
If you want to embed pics in your posts (whether a contributor here or not), read this thread:
http://www.supermotors.net/forums/thid-5972-how-do-i-post-pictures-sounds-and-or-videos
