Swapping in the explorer and 4r70w combo with some crossmember issues. It seems the engine is angled towards the drivers side of the truck which isn't allowing the end of the trans to sit in the middle resulting in the crossmember being shifted two inches over on the drivers side and resting on the frame.
The engine is only resting on the engine mounts with the bolts not yet tight and I cant seem to shift the back end around. Can pry the rear but there is a lot of resistance and just snaps back to the drivers side. I'm using the Wildhorses extreme engine mounts. Is there any way the engine mounts could be out of alignment? I've got the short side of the crossmember on the passenger side which I think is correct.
