Looks like you might need some of the horn contact bits in this kit here: https://www.wildhorses4x4.com/product/Horn_Ring_Contact_Kit_66-73/Bronco_Stock_Column_Parts
But don't ask me how to make them all fit together, because it's been way too long for me!
What does the backside of the wheel look like? Copper traces (two of them) in good shape? Turn signal cancelling cam still intact?
Good luck. Hopefully someone more familiar with the parts and how they go together than I am can lay it all out for you.
I think you need that first kit that DirtDonk pointed you to since it says it replaces everything on the horn button.I see your contacts are pretty good so that first kit should do the trick but seems like something is missing maybe a metal ring that is pressed into the horn ring?I know you need the black plastic piece with three ears because that is what twist locks the ring to the wheel.Oh yeah,a spring is supposed to be between the steering wheel and horn ring.If you can wait until tomorrow and I will take pictures of mine since it is a 1970 model and put them up unless someone else can do it faster than then.
Just be aware that, as you can see in the listings, things changed between '73 and '74, so a '69 wheel will not fit on a '75 column, and vice versa.
I always liked the factory wheels too, but I can see one major reason for changing them out. And that is the size.
A large steering wheel and a 6-turn steering box make for some slow reacting inputs. A smaller wheel helps, where a 4-turn box is not in everbody's budget every time.
And the smaller wheels make it easier to get in and out of the Bronco when real estate between the wheel and the belly don't play nice.;D
Of course, some just change them because they thought it was cool. Until it wasn't...
Paul is correct as usual about years that will fit on a 69 model.I tried to use a 73 year steering wheel and inside the steering wheel on my 70 model is a cup shaped piece of metal and the 73 had a smaller piece of metal that would not make contact with the horn contacts.I can make some pics of it and put them up if you need the 73 steering wheel pics.
Thanks to your information and the pictures that skytrooper posted the 69 Steering wheel is back together and functional. Thanks guys
