From what I can tell, the coefficient of expansion for liquid gasoline is 0.00052 /degree f. So a 23 gal tank, completely full would increase to 23.66 gal. If the temperature went from 45 to 100. You should not get much overflow if you don't burp the tank.
If you do not vent the canister to the air cleaner, the canister will hold vapor until it vents out the chimneys. Eventually, it will stink. If you seal the system up completely, you'll hear the tank creak and pop as it heats and cools. I would find a way to purge the canister.
Best regards,
Ted
I don't think the purge valve is needed but it is not going to hurt anything either. Kind of like giving brand to a horse A wire from the run turminal to a toggle switch to the purge valve would assure that the engine was running when the purge was happening. PS I have been looking into expansion bottles for a while without much luck.Chuck,
I thought it was pretty cool how close you were with your estimate and I can't argue with the experience you guys have installing canisters. Personally, I've come to respect the vapor/liquid separator tank a lot more than I did. I am going to reconnect mine and go with the purge valve set up. I have a SEFI system so everything is in place except the tubing.
Best regards,
Ted
Landshark99 - did you connect as you outlined above? Any problems? Did it solve some of your smell problem???
After all of your help (especially Paul and Nelly) I think I have it figured out, I hope this thread will help others...
The canister with 2 nipples is for a V8, the single nipple they sell is for a V6.
The small nipple is indeed the one that you connect to the fuel tank vent hose.
The large nipple, in this case needs to be capped.
One of the chimneys will get a mushroom cap, which is actually a vented cap.
Finally, and here is my only remaining question..
The last chimney shall either be mushroom capped (thus never getting purged) or shall run to the air cleaner which would provide a minimal vacuum effect possibly purging the CC during operation.
The opening of the chimney is at least an inch in diameter. I need a way to cap it with a nipple and then run it to the air cleaner. I cannot run a 1 inch diameter hose to the air cleaner.
Does such a cap with nipple exist?
Thanks again y'all.
Opps sorry.. forgot to update this thread.. i hate it when people do that!
Yes - I hooked it up as stated above, haven't had any fuel smell but hasn't been too hot here either, that will be the true test. Also I dont top off when I fill up anymore as I have seen a little fuel in the lines after I fill up...
One thing I'm going to modify is adding a "loop" in the vent line. I will run a length of fuel line up the inner fender from the vent on the tank to keep liquid gas out of the lines.. i think with a full (or near full) tank off road I will probably get some fuel in the lines so hopefully 3 high spots in the system will minimize fuel getting sucked into the charcoal canister. Also looking at a one way vapor valve like the 77's have...
