I'm extremely frustrated, hope someone out there can provide some advice!
I'm rebuilding the steering knuckles on my D30. Got the king pins, races etc. out on on side... and am having a heck of a time getting the lower bearing race seated. (haven't even tried the top yet!)
So far, I've tried the following:
* Hammering upside down with my lisle race driver
* Try to drive in with 6" c clamp (ended up bending the screw on the clamp)
* putting end of said driver on a hydraulic bottle jack, lifting up front axle with this, whacking with big hammer
* Loop ratchet strap under hydraulic jack and attach to pivot, jack up to apply tension, whack with hammer.
* Use harbor freight ball joint tool with lisle race driver to try and drive in - no go.
I've got the race driven in so it's about flush with the bottom of the pivot point, meaning it has at least another 1/4" to go. I also put a little grease along the edge of the bushing before driving it in, but it won't budge. What am I missing, any suggestions on tools to use? This isn't my first race replacement, but I believe it's the most difficult one so far.
Other question I have - I have my original kingpins, but also some other ones that have a zerk fitting so grease can be injected. This is probably a really good idea, was this an option on later model D30's (My build date was October 1969 if I recall correctly)? Does a hole or other means need to be created to allow dirty grease to escape, or will the metal axle plug allow some old grease to escape?
Thank you guys!
Thank you guys!
