blknblu69v
- Jul 5, 2012
- 65
69 Bronco, 302, new electric fuel pump/regulator, psi gauge. About 6# psi going to carb via in line fuel filter. Filter does not get over 1/3 full. When engine is hot, I get unstable idle and fuel psi drops to 2# then back up and down. Running on rear tank. Starts hard when hot and near empty filter. Could this be a clogged fuel pick up in the rear tank? Newer plastic tank installed during restoration. Hasn't ran right since, just dealt with it.
Thanks for your help!!
