OEM Wheel Color
SLAYER
Steamboast Springs
Our 74 bronco came with a spare wheel that is white, incorrectly painted wheels ( on the truck ) and an extra set of OEM wheels which are gray...
I searched and found various references to the factory colors, and read about a wheel color switch mid 74 to silver.
I would like to paint the wheels we have either the correct white, or the correct gray ( not the silver ) Does anyone know of a decent / close match in spray paint / enamel or otherwise that would work for the white or the gray?
Our truck is a driver and not a show rig, so I want the correct look but not too concerned with exact PPG paint codes to match etc and would like to blast and paint or powder coat this summer.
Thanks in advance for the help
B RON CO
Statesville, NC
Hi, I thought my wheels on my 66 where Wimbledon white and that's what I went with. I think the other color is Argent, also called Silver Metallic. If your grill center is different than the body color I would think about that color. Good luck
SLAYER
SLAYER
Steamboast Springs
Thanks -- does the wimbledon white sell in aerosol form somewhere or did you just match it from an off the shelf paint? thanks!
I'm not trying for a show-stopper here, just something that "looks" the part.
My 1974 Ford Bronco Explorer had all 5 wheels grey. Bronco was produced June 1974. truck came will the Standard Bronco Hubcaps with red centers. The spare tire carrier was mounted inside the bed on the tailgate if that would have made a difference on what the rim color was used..
Broncitis
MEB Founder
You can get Wimbledon White in spray cans at AutoZone
Sent from my XT1254 using Tapatalk
73azbronco
The grey is most likely Argent. Funny, thats pretty much what all the fancy new cars since around the late 90s have called silver.
No my wheels were not argent they were grey plain old light navy grey. I bought my Bronco with only 10,000 miles on it Christmas eve 1977 I still have them just no longer on my truck. I know the difference between argent and grey.
suckerpunched
mine is a 75 built in late 74. had an argent grill and grey wheels. It is all original paint. the wheels are a very light non metallic grey. I rubbed the oxidation off and snapped a pic for you.
suckerpunched
No I would have to look around, but I think the picture represents the color pretty well. it is really light grey.
suckerpunched
I knew a guy that had an old ford that was Ford Dove Grey. I have seen at least two different colors of what was claimed to be Dove grey, one was a lot darker. The car in the picture is what I have in mind. It is very similar to (maybe the same) as early ford tractor color. the newer New Holland grey is darker. You might be able to still get it at the Ford New Holland tractor dealer or maybe tractor supply.
suckerpunched
I think it will get you pretty darn close
fordfan
The wheel color from '74 to '76 was a 'dove' grey. The '77s had the argent wheels, and before that they were white.
The powder color that very closely matches the correct grey is called 'window grey'.
