Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 12/25/12, 10:12 PM   #1
JHolloway
JHolloway's Avatar
Acworth/Kennesaw, Ga
Will ford alcoa wheels fit a 76-77 bronco?
I think that i read somewhere on here that they required wheel spacers to keep from rubbing. Does anyone have experience with this issue?
1976 ranger
JHolloway is offline
Old 12/25/12, 10:28 PM   #2
jckkys
Tucson, Arizona
I tried every 8" rim Ford made on my '77. They all hit the tie rod ends. Ended up using 8" Dodge 4x4 truck steel rims that work perfectly and they look original with Ford small hub caps for the '78-'79 Broncos. They have a larger CJ center hole but that's not a problem. They are made by Kelsey Hayes.
jckkys is offline
Old 12/25/12, 10:48 PM   #3
bigpitbull
BRONCO ADDICT
bigpitbull's Avatar
Busted Knuckles
Saltillo, MS
eBay: Bigguns26
There are several guys with 76s running alcoas with spacers. I'm not sure how much is required for clearance..
1976 Ranger dark brown- 1976 chrome yellow ranger SOLD -1975 Halfcab build project- 1972 Sport/Explorer package- 1966 U15 caribbean turquoise--1966 U15 Ranch Wagon--(2)1966 U14 halfcabs--1966 U13 arcadian blue 98k original miles from California--(3)1966 U13s-1974 Explorer-SOLD-1974 Explorer Red/Red
bigpitbull is offline
Old 12/26/12, 07:33 AM   #4
JHolloway
JHolloway's Avatar
The wheels im talking about are 7.5" wide. They came on f150s and broncos from 1992-1996, the polished version. What backspacing is required to clear the tierods?
1976 ranger
Old 12/26/12, 08:10 AM   #5
ford man
ford man's Avatar
Nothing run's like a Deere and have you driven a Ford latley
Leesburg, GA
eBay: ebbroncos
So does this mean your keeping the bronco? I thank 1/4 spacer will work with no clamp on wheel weights.3.5 backspace works for sure and I thank the wheels your talking about are 4".
ford man is offline
Old 12/26/12, 08:13 AM   #6
Rox Crusher
Rox Crusher's Avatar
BRONCO TIME !
Roxborough Park, CO
I tried a set of these and they needed about 3/8" thick spacers to barely clear. We used some washers as we were just rolling it around the geerage during rehab.
I am converting to TRO steering which makes the problem worse so gonna convert to the 78 / 79 knuckle arrangement which resolves it.
1977 Sport with 351W Explorer based EFI, 4R70W, 4:88 gears, ARB lockers, 3.5" suspension, 33"x12.5 Shoes
www.coloradoclassicbroncos.com
Rox Crusher is offline
Old 12/26/12, 09:40 AM   #7
Krawlin5
Krawlin5's Avatar
The wheels are a 4" backspace. I torque my wheels and unchecked them after 100 miles still was good. The reason I haven't balanced the tires as they seem to be fine and I use my Bronco off road and they would just be out of balance anyway with all the mud that gets left on the and rocks seem to hit.2012102195164649.jpg
Krawlin5 is offline
Old 12/26/12, 09:44 AM   #8
bmc69
bmc69's Avatar
Maryland
eBay: ford_bill
That. I won't make the mistake again of using the 76/77 knuckles; I never did find a wheel that would clear them and am currently running 1" spacers for the wheels on it now.
'69 retro Bronco. Supercharged MPFI 8BA 239 V-8, C-4/D-20. Hydroboost. 5" lift.
bmc69 is offline
Old 12/26/12, 10:11 AM   #9
JHolloway
JHolloway's Avatar
Thanks for all of the info. Did u have to use spacers Krawlin5?
1976 ranger
Old 12/26/12, 10:14 AM   #10
JHolloway
JHolloway's Avatar
Ford man I got a jbg 2.5" lift kit for christmas so im gonna keep it for now I guess.
1976 ranger
Old 12/26/12, 10:51 AM   #11
Krawlin5
Krawlin5's Avatar
Yes I have spacers I made at work out of alum. 5/16" thick. I guess my first post got deleted. I used longer Gorman studs and Gorrila lug nuts. I bought my rims at a flea market for $175. I only have about 4'' of lift and my tires rub on the front edge of my rear fenders. I need to move my axle back a inch.Tires rub on radius arms at full lock.
Krawlin5 is offline
Thread Tools
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
Copyright 1996-2019 All rights reserved. Privacy Statement
Page generated in 0.29826 seconds with 62 queries
