Thickness of steel backing plates for roll cage??
vtboy51
Gonna have some pieces cut for the underside of the body, what’s the recommended thickness?
wildbill
Old Bronco Guy
;D;D;D Should 3/16" to 1/4" plate steel good luck. :D:D:D Bill %):cool:;D
FordBronc
Polk County, Missouri
X2 on those recommended amounts should be plenty, but remember that they should be bigger in diameter (size) that the top plate foot size. To help spread out any load. Top foot plate 4"x4"..bottom plate 6"x6".
Skiddy
just done this last weekend with 3/16, just watch where the holes go trough and you may have to turn the plates different directions.
1/4 is overkill. 1/8 or 3/16 is what I would consider. For the underside, 1/8 is plenty.
My reasoning is this only really matters if the cage is trying to pull out. The thinner 1/8 can deform but still hold. 1/4 just puts stress lines where it ends, more likely to tear the sheetmetal at that point.
Depending on where the legs line up, it is often on a factory body brace to start with. That make adding plates even more complicated.
