Tom Dummer
Too much time had gone by and my Bronco started showing some wear. (just a little) So under the knife it goes. I've pulled the body off. The entire front clip was torn off the tub with the exception of a 1" weld and 5 fender bolts. The two front mounts were doing OK, but most of the weight was on the radiator. I pulled down an explorer for the engine and transmission but I was HELL BENT on keeping the PTO winch. Last week I was victorious making it all clear. Next is mounting the PTO shafts, then install exhaust around the PTO lines. Then set the body. Then custom wire. Then fuel lines. Then tube front. Then make it all work.
Looks like I have to pull out a plan B for the NBR this year!
