I don't want to do this but I have to.
https://syracuse.craigslist.org/cto/d/1972-vintage-ford-bronco/6390745273.html
I bought it from someone in MI. The best that I can tell, this bronco has spent most of its life in Georgia. The original engine was a 302 and was switched out with a 351W. The VIN stamp from the engine pairs it with a 1971 LTD. The 289/302 & 351 all mount the same so no modification was needed. It does not burn oil or have a heavy smoke exhaust. Compression tests done in 2011 came back normal. It is a 3 on the tree. The 2 barrel carburetor was rebuilt along with changing to an electronic ignition and having the clutch and clutch plate reworked. All major work was completed by a Ford dealership in Kansas City. This includes the breaks, drive train and steering. It runs, drives, and looks great. The interior was done last winter. This was not restored but had a lot of work done to it. Most components were purchased from Tom's Bronco or Jeff's Bronco Graveyard. Below is a list of all items that were done to the Bronco around 2011:
Radiator/Tie Rod/Pittman Arm
Power Steering Kit
4 Wheel Power Disc Brake Kit
Wheel Bearings, Set of 4
Rear Disc Brake Hose, Braided Stainless
Interior Bar Grab Handle
Interior Bar - Family 6 Point
Side Mirror, Fold Away
Soft Top, Black DENIM
Rear Drive Shaft
Drive Shaft Bolt and U Bolt Kit
Transfer Case Yolk
Adjustable Drive Link
Front & Rear Shocks
U Joints
Suspension Bushings
Tie Rod Driver
Spark Plugs
Spark Plug Wires
Brake Lights
Radiator Fan
Radiator Support Brackets
Starter
Alternator
Clutch
Clutch Plate
The following were done last winter:
Radio
Speaker-2 front, 2 year, and 2 mid-range tweeters
Both front floor pans
Entire interior insulated with fake dynomat (roofing material)
Vinyl floor
Seat belts
Steering wheel
Battery
Seats and locking center console
Solenoid
The only things I think it needs are mostly cosmetic. The driver's side rocker panel has a crack in the bondo but is mostly solid metal. The passenger front fender has a minor dent. The hood has some dings. The dash was the only thing not done on the interior. All these could be easily repaired.
This is a solid truck that with some minor work could be worth a lot more.
Gullajrfd is online now Report Post
Power Steering Kit
Rear Drive Shaft
Transfer Case Yolk
Front & Rear Shocks
U Joints
Suspension Bushings
Tie Rod Driver
Spark Plugs
Spark Plug Wires
Brake Lights
Radiator Fan
Starter
Alternator
Clutch
Clutch Plate
Radio
Vinyl floor
Seat belts
Steering wheel
Battery
Solenoid
