I am not getting a reading at the fuel gauge (indicates empty even though there is 5-6 gallons in the tank). I disconnected the harness from the sender mounted in the tank and measured the fuel sender to be 85-86 ohms.
Question 1: What should the ohm range be for the sender?
Question 2: Assuming the harness is okay, how hard is it to replace the gauge on the dash board as well as the sender in the tank?
